long term spare engine storage
if your thinking oil evaporates and rust might be a problem your correct!
OIL and wd 40 run off or evaporate over long periods
http://www.skymartsales.com/lpslabs/ci.asp?OVRAW=lps%20%233&OVKEY=lps%203&OVMTC=standard
http://www.lpslabs.com/Products/CorrosionInh/Lps3.asp
the PRODUCT designed for that application is LPS #3 your local MARINE SUPPLY (BOATS) will more than likely have a good supply, its a spray on waxy, oil film, grease , that stays in place :-D
spray it on ALL unpainted surface metal then place the block or crank in several individually sealed plastic trash bags with(duct tape) if the oil pan is in place I would fill the engine over the crank with oil and place it on an engine stand or off the floor on a pallet or shelf before coating and sealing the engine in the plastic trash bags
BTW it says it stops rust for two years.... thats exposed to air!!! in the trash bags I know from experiances its good for over 10 years
