Please Identify this part of the harness L28ET
violacleff
It's been a while, but I believe you are holding the efi relays which include the relay and voltage modulator for the fuel pump and relay for the ecu, and I remember there being a seporate wire for the injectors. When I did a L28et swap I did away with all of it, wired the fuel pump up directly to be full on when the car was on and had no problems. The fuel pump is a little louder at idle this way, but it is one less thing to worry about.
Here is a bit of writing I did on the subject:
http://zhome.com/~aktar/zcar/73/turbofi/
Best of luck wiring it up. I traced every wire in the 280zx haynes manual. A few wires, like the power for ecu and coil intermix with the chassis wireing harness.
I've since sold the car and my notes along with it, so can't help you any further.
