Thumper Posted November 23, 2004 Share Posted November 23, 2004 I was having some problems starting my car so I decided to bypass my msd 6al and connect the stock wires back to the ignition coil. Well I forgot to turn off the key and for some reason I got alot of sparks when I tried to connect the wires and some popping noise coming from inside the car. Well now I can turn the lights on and thats it. I can't roll up windows or down. The fuel pump doesn't prime. Car won't start and etc... I've checked all the fuses and they are good. So i'm lead to believe it is a main relay. Unfortantely it is raining right now so I can' go out there and play with the electrical system so any help is appreciated. TIA Ted Schmidt Quote Link to comment Share on other sites More sharing options...
Cody 82 ZXT Posted November 23, 2004 Share Posted November 23, 2004 Take a look at your fusible links. Sometimes they can get crusty and not let the car do things. Quote Link to comment Share on other sites More sharing options...
Thumper Posted November 24, 2004 Author Share Posted November 24, 2004 No I am pretty sure nothing is crusty. Since the car was running b4 I blew whatever I blew. Thanks Anyways. Ted Schmidt Quote Link to comment Share on other sites More sharing options...
Guest tony78_280z Posted November 30, 2004 Share Posted November 30, 2004 check all your fuesable links. Did the pop and smoke come from the passanger side of the engine compartment? That is why fuses and fusable links are in the car. So when you short something out like a dumba-- you don't burn up the car. Quote Link to comment Share on other sites More sharing options...
Thumper Posted December 2, 2004 Author Share Posted December 2, 2004 Dang fusible links. Well I found a blown fusible link and a couple of loose connections so I decided to build a new fuse box. I used a 91 sentra fuse board with "REAL" fuses built into it. Everything works great now. Just wanted to give you guys an update and say thanks for your help. Quote Link to comment Share on other sites More sharing options...
