Eagle 028 Series Wheels and Centerline Availability
Anyone here have any experience with the Eagle 028 wheel? I am also looking at Centerline Autodrag, Star, ET and Telstar model wheels, but they evidently have to be custom made as I can find no shop that sells them with the correct bolt pattern, offset etc for my 72 240Z. The Eagle 028 comes off the shelf 15 x 7, 4 x 4.5 bolt circle and 4 in. back spacing which should fit with no problems.
Any info would be appreciated.
Thanks
Miles
Guest mtbrider586
they have some wheels for z car from centerline with the correct pattern and offset. go to the wheel deals section of there web site and select bolt pattern and you will see the choices.
Fred
I ended up going with Eagle 28 series 15 x 7 wheels and 205-50R-15 Toyo Proxes 4 tires. The Eagle wheels were $89.00 each from Summit Racing and the Toyo tires were $80.00 each from Les Schwab. The wheels look good on the car and there is a very noticable improvement in handling.
Miles
