Gollum Posted December 4, 2004 Share Posted December 4, 2004 So, first off... does a pink slip for a 280ZX turbo actually specify turbo on it? Now, my friend who works for the smog ref thinks I could pass off a N/A modified to a turbo as a stock turbo car, unless the person I brought it to actually knew something about the ZX cars, and even then as a last resort I could get a motor swap bar from the ref. SO... What is actually needed to change a L28E into L28ET? Intake (obviously), exhast, what else? Is the compression different? Is the head different? Different cams? Odds are i'll end up canibalising a dead turbo motor since my motor is just over 27k now. But, if the compression is actually different i might just end up buying a L28ET in good shape, or a rebuilt L28ET. (anyone have a link to the person that on3go is getting his motor with? I lost all my links in a recent format doe. Always something i forget to back up.) Quote Link to comment Share on other sites More sharing options...
randy 77zt Posted December 15, 2004 Share Posted December 15, 2004 i have a 77 with 81 motor.it has a bar label in the door-car was certified at ref station.the 81 zxt electronics dont give 21st century driveability.i have a smog license and work as a dealer tech for a ford dealer.dmv renewal always comes back as test only every other year.that sucks since i cant test my own car.but i can pretest it.the na efi system and the turbo efi system are not close to being the same. Quote Link to comment Share on other sites More sharing options...
GrayZee Posted December 18, 2004 Share Posted December 18, 2004 I was always under the impression that because of the lower compression that a turbo engine actually burns cleaner than a n/a So assuming that I am right.. (and I'm not saying that I am) Why would they care if you put a turbo engine in your car? Quote Link to comment Share on other sites More sharing options...
