Guest ss2bp1 Posted December 6, 2004 Share Posted December 6, 2004 Almost finished assembling my Megaquirt and I have a few questions for guys who have already done this. It will be using the stock n/a ignithion from a '77. Step 49: "Diode D8 is needed if ignition has a large offset bias" Do I need this? Step 51: "Capacitor C12 may need to be increased there are noise problems from the tach" Will there be noise problems with the stock tach? Step 54: There are two ways to set up the opto-isolator that recieves the signal from the ignition system. Which way should that be set up? I'll probably be back asking for some starting values once I get all this installed, but that's going to be a few months. Thanks for the help. Greg '77 280Z Quote Link to comment Share on other sites More sharing options...
Tim240z Posted December 6, 2004 Share Posted December 6, 2004 Please do not post your topics in more than one forum...Please read the following: http://hybridz.org/phpbb2/viewtopic.php?t=24170 Quote Link to comment Share on other sites More sharing options...
Guest ss2bp1 Posted December 6, 2004 Share Posted December 6, 2004 sorry about that, won't happen again. Greg Quote Link to comment Share on other sites More sharing options...
dmanzo57 Posted December 21, 2004 Share Posted December 21, 2004 Hi Greg, I first installed my MS unit on a stock n/a '78 280z to test the MS and learn how to program it before installing it on my daily driver V8Z. Step 49: "Diode D8 is needed if ignition has a large offset bias" Do I need this? I did not install this diode and it worked fine. Step 51: "Capacitor C12 may need to be increased there are noise problems from the tach" Will there be noise problems with the stock tach? I did not have any problems with the stock tach. Step 54: There are two ways to set up the opto-isolator that recieves the signal from the ignition system. Which way should that be set up? I have the jumper installed from XG1 to XG2. No problems here either. Good luck with your install, Don Quote Link to comment Share on other sites More sharing options...
