DeusEx Posted December 6, 2004 Share Posted December 6, 2004 I have recently had to remove some valve springs from my head. The valve spring compressor I was using was the one wind on type where one end sits over the retainer and then you wind onto the face of the valve. I can't begin to descrbie how much trouble this thing has been. Some of the valves were downright impossible to get out with this thing. In my datsun book it shows a completely different sort of valve spring compressor that they use. Its a long handle with a big hook on the end, and 3/4 way up the handle there is plunger looking thing which sits on the retainer I guess....Will this make my life a lot easier..and where could I find it ?? Quote Link to comment Share on other sites More sharing options...
Guest Magnum Rockwilder Posted December 6, 2004 Share Posted December 6, 2004 You can get or order a variety of valve spring compressors from Napa. You can also look on Ebay. Quote Link to comment Share on other sites More sharing options...
Guest Magnum Rockwilder Posted December 6, 2004 Share Posted December 6, 2004 I found one like mine on Ebay for $5. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=4509896272&category=35625#ebayphotohosting I would highly suggest that you jump on it. It's designed to hook onto the cam, but I also use it by using a long piece of 1/2" rod wedged under the studs on the side of the head. It takes a little creativity, but it's a great tool. Quote Link to comment Share on other sites More sharing options...
Clifton Posted December 6, 2004 Share Posted December 6, 2004 It's quicker to use a socket and a hammer to get the keepers out. A couple of taps on the retainer and the keepers pop out. I had my 24 valve head apart in about 10 minutes and it's worse than the L head. Still a pain to reassemble as I am using the same compressor you have. Quote Link to comment Share on other sites More sharing options...
Guest Magnum Rockwilder Posted December 6, 2004 Share Posted December 6, 2004 So get the compressor above. It's like $10 shipped, so you have no excuse. Quote Link to comment Share on other sites More sharing options...
