Guest Cronic Posted December 9, 2004 Share Posted December 9, 2004 I just installed a t3/t4 57 trim with a stage 3 .63 a/r exhaust. Im running 17psi, the car is mostly stock. 3" exhaust extra injectors, and FMIC off an Evo 5 and an HKS SSQV. Other then that it's stock. Does anyone have a similar setup dynoed? Quote Link to comment Share on other sites More sharing options...
Guest Magic Posted December 10, 2004 Share Posted December 10, 2004 Yep I have a similar set up. Same turbo. 3inch exhaust. but running CR of 8.3:1 on a P90. 370cc injectors, Huge custom FMC, Autronic engine management. running at 7psi. Got it off the dyno this afternoon after building the engine up from an NA L28. Running 96 Octane fuel. After a 1000km or so I going to try to up it to 15psi. Will post some pics soon if you like. Quote Link to comment Share on other sites More sharing options...
randy 77zt Posted December 10, 2004 Share Posted December 10, 2004 magic-how do you like autronic efi-there is a dealer here in california using it on supercharged big block chevy boat engines.seems they have a fully epoxy potted unit for marine use.probably wouldnt be a bad idea to have a water proof ecm anyway. Quote Link to comment Share on other sites More sharing options...
Guest Cronic Posted December 10, 2004 Share Posted December 10, 2004 Have you dynoed the car yet? Im trying to make 350whp out of this turbo. Quote Link to comment Share on other sites More sharing options...
Guest Magic Posted December 31, 2004 Share Posted December 31, 2004 I have no probs with the Autronic it seems to be reliable and easy to understand and program. Just run my motor in for 1000km on a light tune after rebuild. At 7psi the dyno says 230 rwhp, and that is with 0 degrees timing past 3psi in the boost table. It looks like there is a lot of room for some extra hp. Im hoping to up the boost to 15 psi and connect an electronic boost controller to the autronic in a month or so. Quote Link to comment Share on other sites More sharing options...
Bernardd Posted December 31, 2004 Share Posted December 31, 2004 Cronic, Magic, what rpm are you seeing your boost starting to climb? Are you seeing 5psi before 3k? I'm trying to decide if I should install my stage 3 .63 housing or give the .82 another go with a new wastegate. I wasn't seeing full boost until 4200 with the old setup but with the vac line off it would come up a lot sooner so I think my wastegate was leaking. I'm planning on 20+psi with water/alcohol injection and I don't want to choke off my power with too small of a turbine housing. Bernard Quote Link to comment Share on other sites More sharing options...
envmyz Posted January 4, 2005 Share Posted January 4, 2005 Well I know that I'm at full boost (12) at 3200, so I would say yeah I'm probally at 5 psi at lower rpms. 50/63 trim also. t3/t4 Quote Link to comment Share on other sites More sharing options...
Guest Magic Posted January 5, 2005 Share Posted January 5, 2005 Watching carefully in a high gear my boost climbs from 2000 rpm. I get 7 psi at 2800-2900 rpm. Hope this helps. Quote Link to comment Share on other sites More sharing options...
