VinhZXT Posted September 26, 2006 Share Posted September 26, 2006 HeatRaver, For simplicity you can just weld in a 1" square tubing along the bottom of the rocker all the way from the front to the back. This should give you jacking points any where along the bottom. For the subframe connectors you will need to strip your car down completely and flip it over if you want to do anything like that. If not the welding could be very difficult. Good luck. Vinh Quote Link to comment Share on other sites More sharing options...
Two40MuscleZ Posted September 26, 2006 Share Posted September 26, 2006 Check out Pete Paraska's site...altered Z.com; there you'll find all the information needed to fabricate a multitude of things for your car including measured drawings of sub-frame connectors. Side note, if you are running a V-8 its almost manditory you run connectors. Being a uni-body vehicle the bitch has a tendency of twisting under high rpms. Which can cause stress cracks and body twist. Also, remember to use your Archieveal Search Engine for this site to retrieve information. VAN Quote Link to comment Share on other sites More sharing options...
