v8 z question
Guest 83supaZ
Guest 83supaZ
i am in the process of building a 383 stroker.. how much HP can the ZX handle (mine has t-tops) without twisting and t-tops leaking.. i wont be racing it ALL the time.. but it will get drove at the track sometimes.. wanting to know if i need a roll cage? and anyone know what speed in the 1/4 REQUIRES a roll cage.. i'd imagine the z's are FAST w/a 383... can you guys that have a 383 post your 1/4 mile times.. and engine setups if you dont mind?
Guest 83supaZ
LoL yeah i probably will be until the gas mileage bites me in the a##!! so would a 383.. with stock 74cc heads w/port polish.. pistons to bring compression around 10:3.1.. edelbrock rpm intake.. holley 650 double pumper.. lunati voodoo cam with duration @ .050 233*/241* lift .504/.525 LSA/ICL 110/105 rpm range 2200-6400 2400 converter stall in a 280zx run 11's? how much hp u think it would have?
Guest SC457A
11s will be close, but im thinking mid 12's. my combo is similar, but i have better heads, more stall, slightly larger mild roller cam. and its more for racing than street. but i baby it at the track. shift low (5500-6000)
hp id guess 300-350 at flywheel
my old combo is pretty close to yours. ran best of 12.90s at 106 mph on a 235/60/14 tire. your cam is larger than mine was.
but im lazy and don't tune a lot.
Hey. Stop building that 383. Get in touch with Mike Kelly.
(he is a list administrator)
He has a newly built 383 for sale. If he sells it, he can install his LS1 in his Z instead.
