Hydraulic Slave On A Muncie M21
v80z
I did.
This was a long time ago, but if I remember correctly I used an 85 200sx slave cylinder and a the JTR specified sized Master cylinder. Clutch was still heavy as crap and had problems engaging correctly. I made a bracket to hold the slave as it wont bolt up as is. Used a corvette clutch fork.
Guest 350zgto
Yes. Any push slave will work. Go for 7/8" to 1" bore. You want 1" travel, forget foreign car cylinders, they are too small. Bracket of .25" off the back of the engine block. Make a pushrod from a hardened bolt. Grind 4 flats on it so you can adjust it with a 3/8" open end.
