80LS1T Posted January 16, 2005 Share Posted January 16, 2005 I need to get a MAF for my LT1 and I dont know if I should just get a used stock MAF or should I spend the money and get an aftermarket one? I just dont want to spend $250 for a MAF if I am not going to see really any gains in power. Thanks, Guy Quote Link to comment Share on other sites More sharing options...
240Z-DET Posted January 16, 2005 Share Posted January 16, 2005 From what I've been researching, it seems as if modifying the stock MAF by removing the screens and installing a portedinlet/outlet will achieve the same HP. The gains I've found range from 0 to 1 RWHP. I was also looking at doing the same for my LT1 and it's money best spent elsewhere. One advantage may be a slightly quicker throttle response, but for $250, personally I'm skipping it. Quote Link to comment Share on other sites More sharing options...
Guest Phil1934 Posted January 16, 2005 Share Posted January 16, 2005 The LT1 MAF is twice as large as the Ford 5.0 so I'd say no. I just did a Ford with a bigger MAF only because it was calibrated to larger injectors so I could still run the Ford computer. Quote Link to comment Share on other sites More sharing options...
love-my-V8-280Z Posted January 17, 2005 Share Posted January 17, 2005 I agree, I have read over and over that its not worth buying a larger MAS. Also have read that some people have regreted removing the fin and screen, I don't remember why... Quote Link to comment Share on other sites More sharing options...
Guest AJ78 Posted January 17, 2005 Share Posted January 17, 2005 I agree' date=' I have read over and over that its not worth buying a larger MAS.Also have read that some people have regreted removing the fin and screen, I don't remember why...[/quote'] The fins and screen are made to direct the airflow over the hot wire, and if you remove them, it causes turbulence, which leads to poor MAF readings. Quote Link to comment Share on other sites More sharing options...
80LS1T Posted January 17, 2005 Author Share Posted January 17, 2005 I kinda figured that money would be better spent else where. I think I will just buy a stock one and leave it like that. Anybody have a stock one in good condtion lying around that they want to get rid of? Guy Quote Link to comment Share on other sites More sharing options...
