S13 LS1 T-56 project
If you guys couls look over what I've come up with so far and help me fill in the gaps or fix problems with the ideas it would be much appreciated.
I thought this would be a fun and unique project, maybe even a modern version of the 240Z's with carbed sbc's. I've spent quite a while planning and researching possibility and parts to complete the project. Yes I know the difficulty is pretty far up there but I want a challenge.
The general idea is an S13 coupe with complete JDM bodywork and drift bodykit/suspension but having the mellow rumble and power of the chevy V8.
The car will be factory Nissan gloss black and hyperblack rims 17" front 18" back, width is undetermined as of now.
Here it is in more detail:
Parts List
"?" = price varies greatly or is unknown
Chassis
-Tanabe Sustec rear-subframe ridge collars $208.25
-Cusco radius lower bar front $81.43
Body
-JDM beam projector oem headlights ?
-JDM oem headlight brackets (ebay seller raceonusa) $59.99
-JDM oem corner lights (ebay seller raceonusa) $139.99
-JDM fiberglass mesh grill (ebay seller v-mods) $49.99 or carbon fiber for $119.99
or JDM OEM GT-R grill $90
-JDM OEM carbon fiber front fenders (ebay seller v-mods) $389.99
-JDM OEM GP Sports G-Four Aero carbon fiber hood $1,113.21 or Raceon carbon fiber D1 hood with reverse scoop (ebay seller raceonusa) $749.98
-GP Sports G-Four Aero front bumper $694.26
-GP Sports G-Four Aero full aero set $1,771.56
Suspension
-Cusco tension rod $230
-Cusco toe control arm$281.71
-Cusco adjustable rear upper control arm $310.86
-Cusco front upper link $281.71
-Cusco coilovers Zero-2R normal $2,094.64
-Cusco lower arm bushings. $165.14
-Cusco upper rear pillow ball mount $213.71
-Cusco upper front pillow ball mount$213.71
-Cusco rear strut bar type-40 $174.86
-Cusco front strut bar type-40D $145.71
-Cusco rear sway bar 18mm. $192.26
-Cusco front sway bar 28mm $252.98
-Signal Auto 5 lug conversion hubs front $470
-Superior Nissan Motorsports OEM rear 5 lug hubs and bearings $450
-master polyurethane bushing kit (Prothane?) ?
Brakes
-300zx TT Brembo GT 332mm big brake kit front red caliper $2,875
-Project Silvia rear stainless steel brake lines $55
-Brembo rear sport cross drilled rotors $144
-rear performance brake pads ?
-rear remanufactured calipers red ?
Wheels and Tires
Engine and Transmission
-Chevrolet f-body 97-98 LS1 ?
-Chevrolet f-body T-56 6-speed transmission?
-Flowmaster Hush Power II mufflers 4x$167.93
-f-body clutch master cylinder ?
-short shifter—Hurst Billet/Plus Shifter (Jegs) $165.99
or B&M Ripper Shifter (Jegs) $164.99
-performance clutch—Centerforce Dual Friction clutch 90% stronger than stock (Jegs)$383.99
or Excedy Stage 4 clutch for up to 750hp (Jegs) $1,719.99
-Fidanza lightweight flywheel (Jegs) $379.99
-Inland Empire Driveline custom driveshaft (steel, aluminum, or carbon fiber) ?
-Weiand polished aluminum intake manifold (Jegs) $819.99
Fuel System
-Summit Racing aluminum 10 gallon fuel cell SUM-290210B—powder coated red $209.95
-Summit Racing complete fuel system kit SUM-PUMPKIT7A $269.95
-Edelbrock EFI electric inline electric external fuel pump $399.99
Drive train
-Cusco LSD MZ $865.79
-Greddy high capacity rear differential cover R200 $240
-Circuit Worx billet axles/half-shafts (http://www.g-dimension.com) $658
Electrical
-Painless 97-98 LS1 standalone wiring harness $499.99
Interior
-Sparco Sprint racing seats-red 2x$279
-Sparco universal base mount 2x$65
-Sparco seat track set 2x$49
-Sparco Globe-X shift knob black $69
-Sparco Stripe-Manual standard pedals black $79
-Sparco harness pads style R2 2x$25
-Sparco Flash 5 steering wheel black/silver $259
-Sparco steering wheel hub adapter $65
-Sparco steering wheel quick release-tuning black $299
-Sparco steering wheel spacer silver $79
-Sparco harness clubman 4 point bolt in black 2x$95
-roll cage padding ?
Parts list Total is currently $21,496.32 not including "?" items
Services List
Chassis
-Rhino Lining coated floorboards and interior
-Rhino Lining coated underside of unibody
-Rhino Lining coated engine bay
-powder coated roll cage low gloss black
-powder coated front sub frame--low gloss black
-powder coated rear sub frame--low gloss black
-powder coated engine mounts—low gloss black
-powder coated transmission mounts—low gloss black
-powder coated brake calipers—red
Body
-window tint—15% behind doors 35% doors and windshield
Suspension
Brakes
Wheels and Tires
Drive train
-custom driveshaft
Fuel System
Electrical
Interior
-powder coated custom seat brackets—low gloss black
Fabrication list
Chassis
-custom NASCAR style chromoly roll cage
-shaved fuel door
-shaved antenna
-engine mounts or tubular engine cradle
-transmission mounts
Body
-seam welded unibody
-chop top with windshield laid back?
-exhaust port in right rear bumper to mirror stock left
Suspension
Brakes
Wheels and Tires
-carbon fiber “Corvette†style LS1 engine covers with no lettering
-true dual stainless steel exhaust 2.5†with 3†polished tips
-mount f-body clutch master cylinder
Fuel System
-everything
Drive train
-driveshaft to mate Chevrolet T-56 to Nissan R200 LSD
Electrical
-stand alone engine management (wired into chassis electrical?)
Interior
-seat brackets
Guest 240zJake
Wow its excellent that you have such an extensive plan, the best advice is to stick to it. That said, have you seen these suspension components? LINK
Very cool for high horsepower applications, fully adjustable, very nice.
The GM 'F' bodies had the LS1 form '98-02. Only the C-5 Corvette had it in '97. I would recommend getting on http://www.ls1tech.com and getting recommendations on the LS1's - they are not all the same. The '01 & '02 come with the LS6 intake and some of them also come with the LS6 block. The '98 LS1 does not have as good a valve train as the later LS1's. Need to do some more research on the engine.
240zJake: I took a long time to check the SPL website out and was very impressed. My suspension catagory has been altered quite a bit. Thanks
Phantom: I have been looking at LS1tech.com for about two weeks now trying to read as much as possible. I'm planning on installing a stock motor and tranny for now to see how the chassis handles it and to keep things simple. The only upgrades that could come soon are the clutch/shifter and some nos.
This is the area that I need to do the most learning in. Thanks for the tip.
