Suspension question
Hi All,
Well I am trying to figure out my suspension better. I have replaced the struts with KYB in the front and I still have to get the back replaced, to much cold weather and snow right now to do that. I did find out that whom ever replaced the struts before used Monroe Matics, yuk!! And I do have new struts in the back but they are junk so they will be replaced with KYB's.
So here is what I am after. My measurement from wheel center to fender edge is as follows:
Front is 15 1/4" Stock I think, not really sure!
Rear is 15" does have 2+2 springs!
I hope to get measurements from others with 280Z, both stock and with after market springs, please tell me what springs you have. That way I can determine what I need to do to fix my ride height problem. Also I did a search but did not find anything like I am asking for. Thanks for your help.
HB280ZT
I get 13" (rear) from center wheel to fender lip.
Can`t measure front, no motor in the car right now.
Mine is lowered a bit and MSA aftermarket springs (don`t waste your money on them).
If you have 2+2 springs, you can cut some coils off to lower the car.
If they are old, might be better (time spent) to just get some new aftermarket springs and start from there.
I would also find out the tire diameter of the tire you would plan to use on the car as a means to determine the suitability of your suspension height. A 25" tire would have a 12.5" radius, add another 1" for a fairly descent visual gap, and you have 13.5" distance from axle centerline to the fender lip as measured vertically only (no angle outward toward the fender).
Thanks for the info.
Right now I am running 25" tires and plan to stay with them. Now I may go wider in time but right now my 225 x 60 R15 are just fine.
The only problem that I have with going lower is that I am running a 3" exhaust and it hanges down very low so I either need to try and move it up but I can only go so far or see what I can do about getting some custom springs made. Or I can just go with the adjustable ones like Ross sells??
Thanks again but hope to see more info on this subject.
HB280ZT
  • 3 weeks later...
Guest Phil1934
Chevette springs are Moog 6556, look like stockers but 2 coils shorter. Stiffer though, so I got 19" axle to fender lip and had 17" stock. I'll cut 2 coils. These are for rears. About 250#/" listed on this forum, but Moog probably has a web site with rates.
