Guest tony78_280z Posted January 20, 2005 Share Posted January 20, 2005 I drove my Z all the way home (about 2 miles) on about 8 volts. Dim lights, poor dash, you know the symptoms. Within 2 blocks of my house I got pissy and floored it at a stop sign. It was Slinging rocks with roaring exhaust (it was fun) and BAM!, its up to 14 volts! Dash got bright, headlights jumped awake, like nothing was the problem. What causes this? It is a new (replaced since last posting) Alternator. Is it going bad too? Why is my Alternator not charging at lower RPMs and lower speeds. You could say my Idle is set too low,.. but I drove it for almost 2 miles at about 35-45mph. It didn't charge until I realy gunned it. Quote Link to comment Share on other sites More sharing options...
Guest neo997x Posted January 24, 2005 Share Posted January 24, 2005 make sure your belts are nice and tight so that the alt isn't slipping Quote Link to comment Share on other sites More sharing options...
Guest tony78_280z Posted January 24, 2005 Share Posted January 24, 2005 You know... I have the alternator belt off by a tooth, and I'll check and update on this. But I'm thinking that it was doing this before it was off. Never know though. Sometimes it's the simple and overlooked. I hope =) Quote Link to comment Share on other sites More sharing options...
Guest neo997x Posted January 28, 2005 Share Posted January 28, 2005 i always over think these types of problems best bet is to usually look in a the simple easy places before you waste time and money Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted January 28, 2005 Share Posted January 28, 2005 The old Z's had external voltage regulators. Mechanical ones at that. If that is bad or sticking, then it would cause your problems. If you have a newer one the regulator will be in the alternator. But you still have a voltage sensing wire that tells the internal regulator what the system voltage is. Either way, a corroded connector or if the sensing wire is chaffed and grounding out somewhere, then that could cause your problem. A bad engine ground is another thing to look for. Any electrical gremlin like that could be fixed by a strong mechanical "jolt". And with any electrical problem the first thing you do is clean your battery posts whether you think they need it or not. Quote Link to comment Share on other sites More sharing options...
mark Posted January 28, 2005 Share Posted January 28, 2005 I'm assuming that you are using a GM one wire alt with your set up. Check to make sure the connection for the sensing wire is good. Put a volt meter on it and wiggle the wire and make sure that connection is good. A bad connection at the sensing wire will cause intermintent charging. Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted January 28, 2005 Share Posted January 28, 2005 If it is a one wire, you need to rev it up past 2000rpm to kick it on Quote Link to comment Share on other sites More sharing options...
Guest tony78_280z Posted January 28, 2005 Share Posted January 28, 2005 I have one wire coming off of the alternator that goes into the battery +. And the sensing wire splices back into this same wire as most diagrams for my Alternator type says to do. It is soddered into the wire. The plug isn't of the highest quality, perhaps I should replace it too. All connections are clean and new. Even the battery. There is no corosion to be found anywhere. Thanks for the Idears though Quote Link to comment Share on other sites More sharing options...
mark Posted January 28, 2005 Share Posted January 28, 2005 The plug isn't of the highest quality, Mine was bad, it was the original GM connector. It took me forever to isolate the problem. Bought a new one from the dealer and no problems since. Good luck Quote Link to comment Share on other sites More sharing options...
Guest tony78_280z Posted January 28, 2005 Share Posted January 28, 2005 K, replacing that plug ASAP! Dang, a friend just borrowed all my tools until Tuesday, OMG what am I gonna do.. I'm all alone =( Quote Link to comment Share on other sites More sharing options...
