Adimir Posted January 26, 2005 Share Posted January 26, 2005 building a t04 turbo engine out of an NA engine....do i need a heavier bottom end or is the NA gonna do? Quote Link to comment Share on other sites More sharing options...
Drax240z Posted January 26, 2005 Share Posted January 26, 2005 Read the FAQ at the top of this forum... you are fine probably, depending on the specifics of your setup. Try to provide us with a bit more information. (what head, what pistons, what CR, what intercooler, etc.) Quote Link to comment Share on other sites More sharing options...
Adimir Posted January 26, 2005 Author Share Posted January 26, 2005 well its a NA f54 block, N42 head...i was going to get turbo pistons, and i got a spearco intercooler...its a fair size .... Quote Link to comment Share on other sites More sharing options...
yo2001 Posted January 26, 2005 Share Posted January 26, 2005 Should be fine as long as there is no detonation. Quote Link to comment Share on other sites More sharing options...
Adimir Posted January 26, 2005 Author Share Posted January 26, 2005 alrighty...cuz i talked to a guy and he jus told me to make sure that my NA block, crank, rods are gonna be fine before i go ahead and put everything together. I was going to get a 1mm copper HG, or should i go with 2mm to lover the compression even more... im going with a 255lph walbro pump, 440cc injectors and aeromotive fpr and megasquirt for fuel control so i hope ill get it programmed right...that will dump enough fuel in there as long as i tune it right (my weakness.) yeah drax i have read that too, its alot of help...and i plan on redoing my head, and oring it too just to add extra safety..or would you recommend oring the block? illl add more questions if i think of them later....i just dont want to put it together and then sombody tells me....well thats not gona hold up at all... Quote Link to comment Share on other sites More sharing options...
Drax240z Posted January 26, 2005 Share Posted January 26, 2005 You should be fine with just a metal headgasket. I am running a N42/turbo piston setup which is right around 8.3:1CR. The 1mm gasket will put you around 8.5:1 which should be fine with a quality intercooler and good fuel control, which you seem to have taken into account. Sounds like you are on the right track. Quote Link to comment Share on other sites More sharing options...
Adimir Posted January 26, 2005 Author Share Posted January 26, 2005 so just gasket, not oring? thanks i like hearing it from sombody that is sure of their answer. Quote Link to comment Share on other sites More sharing options...
Drax240z Posted January 26, 2005 Share Posted January 26, 2005 A metal headgasket should be fine without o-ringing. What are your power goals? Quote Link to comment Share on other sites More sharing options...
Adimir Posted January 26, 2005 Author Share Posted January 26, 2005 i want to really take it to 300 ...but not keep it there... just get there when i want ya know....i want 250 for daily driving....i dont know if im shooting high here but thats what i would like... Quote Link to comment Share on other sites More sharing options...
datsunlover Posted January 26, 2005 Share Posted January 26, 2005 I think 250 should be easy to get out of the L28et.. Heck, 250 isn't too hard to get from a N/A L28.. Quote Link to comment Share on other sites More sharing options...
Adimir Posted January 27, 2005 Author Share Posted January 27, 2005 yes but im converting NA to turbo...and im asking questions reason being im worried if my na internals (rods, crank, even the NA block) can handle the boosted power...i know turbo zx can easily do 250... Quote Link to comment Share on other sites More sharing options...
