tfreer85 Posted February 4, 2005 Share Posted February 4, 2005 Okay, can anyone tell me what type of clutch assembly a RB25DET transmission has? I currently have a stock engine and automatic tranny in my 70 240Z. The RB is a manual, i need to convert the 240Z to work properly with the RB transmission. What do i need to do? Would finding a clutch assebly off the same year 240 work? Any help would be great. Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted February 4, 2005 Share Posted February 4, 2005 Find some one to sell you all the pieces off a 1st gen Z car with a manual trans (pedal assembly, master cyl) and that should fix you up. Except for the slave cyl on the trans (for the clutch fork) its all Z car parts... Quote Link to comment Share on other sites More sharing options...
tfreer85 Posted February 4, 2005 Author Share Posted February 4, 2005 Find some one to sell you all the pieces off a 1st gen Z car with a manual trans (pedal assembly' date=' master cyl) and that should fix you up. Except for the slave cyl on the trans (for the clutch fork) its all Z car parts...[/quote'] just the pedal assembly and master cylinder is all i need. and where would i find the slave cylinder and do i need it .sorry if this is redundent i don't know trannies i know engines. Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted February 4, 2005 Share Posted February 4, 2005 Sent you a pm. You can use the RB slave. It should be attached to your engine assembly when you get it. Quote Link to comment Share on other sites More sharing options...
