HEI modules
Phyxius
O.K> THIRD TIME TRYING TO POST THIS!
Short and sweet before something happens again.
HEI Aftermarket like Pertronix Flamethrower 100mm spark, blue white, cranking and idle speed. No over 4500 dwell and spark dropoff like stock HEI modules.
Nissan Module, hard to find on the road, expensive, spark production less than the $40 aftermarket HEI's available!
The 4 pin HEI module controls dwell. 7 pin HEI does not. Nissan module????
MSnS code does not control dwell, so.....
MSnS_Extra code can control dwell, but that function is experimental.
My suggestion, use either code you like, use 4 pin HEI module and know that dwell is controlled, unless you like to experiment with this stuff :)
