datsunan Posted February 16, 2005 Share Posted February 16, 2005 This may be a stupid question but I dont ungerstand why a wastegate needs to have a spring matched to boost pressure. Is this only needed if you are not using some sort of boost controller and are locked in to one pressure ie the spring rate? If I'm using a boost controller what spring rate should I get? Most of the springs I see are low psi. Thanks Paul. Quote Link to comment Share on other sites More sharing options...
