Fuel pressure question..........
80LS1T
Ok I am installing new 3/8" hardline, -6AN 37* fittings, new fuel pump(in stock location), and new cartridge style fuel filter(on the firewall).
Now with the new lines I do not have a port to check fuel pressure. If I install a guage on the fuel filter(it has 2 inlet ports and 2 outlet ports, and I am only using 1 of each) will it still read the same pressure as the fuel rail? Or do I need the guage to be after the regulator? The regulator is on the return side of the fuel rail on my LT1.
I guess what I am getting at is does it matter where you take a pressure reading if the regulator is up on the rail? The way I am thinking is that it wont matter.....but am I right? :-)
Thanks,
Guy
Ok thats what I though. I also asked an "older" technican at work yesterday about this, he also said just as long as its before the regulator it will be fine.
So I will be mounting a guage off the other outlet port on the fuel filter! :-)
Thanks guys!
Guy
