Charging system question..
Guest Brian260ZT
Guest Brian260ZT
I'll try to make this brief :)
Car: 1974 260Z
Problem: While the car is running, and only sometimes, the charging output of the alternator is not making it back into the car's electrical system.
How do I know? The AMP meter reads below the mid-mark, the lights start dimming, etc.
Then (while driving) I'll hear a click (could just be the AMP meter) and the charging system will be working as normal.
This was occuring with my original alternator with an external regulator. I have converted to an internal regulated alternator.
Looking at the wiring diagram I don't see any relays .. I do see a mechanical 'shunt' that is located just below the external regulator.
Any ideas?
Thanks,
Brian
I belive you allready found it "The Shunt" is the first place i would look , im not really sure how the item works but i do know it has something to do with the Ampmeter showing Charge or Discharge.The book says there are two 3 amp fuses in there. I would take the cap off and make sure the fuse holders are clean and then replace the fuses.
Or i guess it could be the voltage reg itself,did you replace it yet?I might be wrong but i think the book means teh Shunt works the amp guage. but not sure?
Im pretty sure someone will chime in on this has more info than i . i dont have the stock charging sys on my car anymore.
G/L
Rob P
Guest Brian260ZT
I looked at the 'Shunt', it has no type of switching mechanism in it. It's just a glorified resister for the AMP guage.
I'll keep looking...
thanks!
Brian
  • 1 month later...
