Bartman Posted March 2, 2005 Share Posted March 2, 2005 I thought I was going to be able to get away with using my stock fuel lines to start, but after looking through search results it doesn't look like I'm going to be able to get away with this. Is it possible to use them on my LT1 or not? I wanted to just use them temporarily until I decide what I want to do with my fuel tank (use a fuel cell, LS1 tank, or something else). Although I can't find it now, I thought there were some people using the existing supply as supply and the existing vent line as a return. I'm tired of having my car apart and parts sitting everywhere, and I really want my engine to be installed and running ASAP;) . Quote Link to comment Share on other sites More sharing options...
Tim240z Posted March 2, 2005 Share Posted March 2, 2005 That should be adequate as you have described above. I used -8 Army Navy lines for feed and -6 for return. The stock lines are about that same size. Tim Quote Link to comment Share on other sites More sharing options...
Bartman Posted March 2, 2005 Author Share Posted March 2, 2005 That should be adequate as you have described above.I used -8 Army Navy lines for feed and -6 for return. The stock lines are about that same size. Tim Alright, some good news:shock: . What fittings do I need to connect my existing hard lines to the LT1? I already have the hard lines routed up the firewall where they need to be. Quote Link to comment Share on other sites More sharing options...
Guest DISCUS Posted March 2, 2005 Share Posted March 2, 2005 Alright' date=' some good news:shock: . What fittings do I need to connect my existing hard lines to the LT1? I already have the hard lines routed up the firewall where they need to be.[/quote'] I just used High Pressure fuel injection Hose of appropriate diameter and clamps! Still running original fuel lines. However do reccomend double fuel pump set up to fuel a reservoir and high pressure injection pump for proper results with the LT1. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted March 2, 2005 Share Posted March 2, 2005 You should have the braided hose with the LT1 quick connect fittings. Use those and clamps. Tim Quote Link to comment Share on other sites More sharing options...
randy 77zt Posted March 4, 2005 Share Posted March 4, 2005 a company called street&performance makes an adaptor fitting kit to put an fittings on lt1 fuel rail and return off of fuel pressure regulator. Quote Link to comment Share on other sites More sharing options...
Bartman Posted March 5, 2005 Author Share Posted March 5, 2005 a company called street&performance makes an adaptor fitting kit to put an fittings on lt1 fuel rail and return off of fuel pressure regulator.Thanks, I actually found their web site the other day and was looking at their adaptor kits. On closer inspection of my engine I already have the quick connectors:redface:, and all I need to get is the high pressure fuel line and hose clamps to connect up to my existing hard lines. I'm still hoping to test fit the engine and transmission this weekend and figure out what else I need to get it running:rockon:. Quote Link to comment Share on other sites More sharing options...
Guest DirtyDingoMoto Posted August 14, 2007 Share Posted August 14, 2007 A company called http://newoldstockmotorsports.com sells 3/8 stainless CNC bent fuel lines for the Z car. Just purchased fuel and brake lines...Good luck. Quote Link to comment Share on other sites More sharing options...
