Guest zspeed77 Posted March 3, 2005 Share Posted March 3, 2005 I'm putting an F9 on my turbo z shortly and was curious if anybody using haltech could share a map with me to help get started. My car is a daily driver so I need to keep the down time to a minimum if possible. I'm using 30lb injectors and probably will run 12-15 lbs of boost when it's all said and done. Quote Link to comment Share on other sites More sharing options...
violacleff Posted March 8, 2005 Share Posted March 8, 2005 There was a guy on zcar.com that was asking if anyone needed a good F9 map. Look it up in the search. There's a few guys on there that have it. Quote Link to comment Share on other sites More sharing options...
Ben Posted March 14, 2005 Share Posted March 14, 2005 If I was you, I'd seriously consider selling the F9 to someone who has less need for full ignition control & getting a fuel/ignition computer to replace it (E6A or better). Turbo cars require reasonably complex timing maps to run at their best (and most reliable), and unless you plan on fitting some kind of stand-alone ignition controller, you will not get anywhere near the full potential from your engine. Quote Link to comment Share on other sites More sharing options...
