dsommer Posted March 4, 2005 Share Posted March 4, 2005 So I bought Mike Kellys CV axles last spring... While I'm at it; I'll swap out the rear end gearing for a 3.54 something lower than other than the 3.9 I'm running. While I'm at it... If I have to pull that rear end I've always wanted an LSD unit, go shopping... found LSD (thanks HybridZ member!!!!) Hey while I'm at it... Damn I've got a 240Z, I need to put 280Z stub axles in there to make the companion flanges fit...pound, pound, pound...grinder, cuss, machine shop order new bearings from Arizona Z car. Hey since I have the stub axles out might as well go with the full on Big Brake Kit from AZ Z!!!! Placing my order tomorrow for fronts and back disk brake kits!!! Oh sh*t while I'm at it got me again... oh well Quote Link to comment Share on other sites More sharing options...
datsunan Posted March 4, 2005 Share Posted March 4, 2005 I'v got the same thing going on in my garage. Started with a new fuel pump and could not control fuel pressure, so, install larger lines, may as well put in a new FPR and JSK fuel rail. That fuel rail is really going to clean up my intake manifold, I think I'll cut off my EGR and EVERYTHING else that I'm not using, to much work to do it to my turbo manifold so I bought a mani fom a 77 280 much easier to clean off. Cut off all cast marks and screw holes I don't need grind it down and polish it. I wanna see how clean I can get it so I cut off the linkage for the throttle and I'm running it down the side of the mani, that means I need to flip the throttle body over so the stem is now pointing at the driver side shock tower and my TPS is on the inside of the TB. That looks much better. I though I was doing my fuel system? I have had problems with my engine starving for fuel under hard braking so I should fab up a surge tank, since I'm fabing a surge tank I don't need my sump sticking out the back anymore, I can turn my fuel cell around now. Oh did I forget to mention that my boost was not stable so I wanted to put in an external wastegate, may as well put in a new 3" down pipe while I'm here! My wife said something about me having A.D.D. but I was buisy doing three other things and could not understand what she was saying. Quote Link to comment Share on other sites More sharing options...
