SHO-Z Posted March 6, 2005 Share Posted March 6, 2005 I need some help trying to figure out where to start on the jetting on my forced induction project. I have triple 45 MM SK Racing Carbs with 33 MM Chokes, Weber Clones. SKs use weber jets. I am planning on running around 11 psi of boost. From my calculations I will be feeding air equal to a 5 liter engine through the carbs. I have gone through the weber jetting articles on the web and seem to be missing something. If anyone has any input on were to start with the jetting I would appreciate the help. Quote Link to comment Share on other sites More sharing options...
datsunlover Posted March 6, 2005 Share Posted March 6, 2005 I'm not much help on webers, but a guy here I know had webers on his car for a while, and seamed to know quite a bit about them. His handle on Hybridz is "ZR8ED" .. Hope thats of some help.. Quote Link to comment Share on other sites More sharing options...
SHO-Z Posted March 24, 2005 Author Share Posted March 24, 2005 I have checked to see what I have now. tripple 45 MM Carbs 34 MM Venturi Jets Mains 135 Tube F11 Air 165 Idle 50 If I calculate using the area of the jets from increased air flow of 1.8 times more air @ 12 PSI of Boost Mains 180 Tube F11 Air 155 Idle 65 I really feel that these are larger than I need. Any of you weber experts please give me your input. Quote Link to comment Share on other sites More sharing options...
Guest 81na ZX Posted March 25, 2005 Share Posted March 25, 2005 Are you running blow through or draw through? "stock" Webers won't hold up to positive pressure (so no blow through). I personally though for draw through you kept the fuel almost exactly the same but a little richer, cause its just pulling in more air. Quote Link to comment Share on other sites More sharing options...
SHO-Z Posted March 26, 2005 Author Share Posted March 26, 2005 I have found several people using blowthrough webers and SKs using turbos. It is also metioned in my Weber book. I am going to try this and see if it will work for me. If it doen't work I will try using the supercharger wet. Quote Link to comment Share on other sites More sharing options...
