7mgte or 7mge
gexgexgexgex
i want to put either a toyota supra motor mkIII motor in my 240z and i dont know if i should use the 7mgte or the 7mge. the 7mgte is the turbo motor and has coil packs the 7mge doesnt have coil packs and is n/a. no mater what motor i pick i will turbo it, but i want to run megasquirt and spark to control it so should i go wit the easyer no coil packs or the harder coil pack motor to power my 240z
Guest 81na ZX
Well you could convert either to an EDIS system, or, if its possible, put the NA distributor on a turbo motor.
but either way, you should start with the turbo motor - supposedly theres alot of differences.
You want the 7MGTE. The heads are excatly the same, different cams. N/A has more duration. The n/a has higher compression, not good for turbo. You can use the n/a distributor inthe GTE head or use EDIS as 81na ZX said. I'm looking into this or AEM or something, tired of a 6600 rpm rev limit and AFM.
