Guest ken280zx Posted March 13, 2005 Share Posted March 13, 2005 I bought an 82 turbo 2+2 that didn't run for two years. Once I got it home I drain the oil( that was ugly). I drained the radiator. I pulled the injectors and had them cleaned and tested. Pulled off the fuel filter and let as much of the gas drain from the tank. I finally got the oil filter off. put oil in each of the cylinders and put new plus in. New cleaned injectors ,new gas ,oil,checked the spark plug wires to make sure they where in the right order. vaccum hoses look good. Put new starter on and got her to run. Some smoke at first but thats to be excepted. The problem that I am having is that it well not idle. The second I take my foot off the gas it dies. Other wise it runs good. ???? Ken Quote Link to comment Share on other sites More sharing options...
datsunlover Posted March 13, 2005 Share Posted March 13, 2005 Kinda hard to diagnose without a little more info... when you keep your foot on the gas, does it run well? Or sputter and bog? Does it do it when cold AND warm? Can you drive the car around at all? First thing's I would check are ALL the wiring conections to the AFM, TPS, cold start valve, ect. Quote Link to comment Share on other sites More sharing options...
Guest ken280zx Posted March 13, 2005 Share Posted March 13, 2005 Yes it runs good. Can't drive it though because its an automatic and like I sasid the second I take my foot off the pedal it dies. This morning I started it and it did idle but with in a few minutes ( alittle warm up) it died. It does run smooth when I keep the RPM's up say around 1000 or so and when I do rev it up it sounds good. ken Quote Link to comment Share on other sites More sharing options...
savageskaterkid Posted March 13, 2005 Share Posted March 13, 2005 i had the EXACT same problem, try changing ur dizzy cap and rotor, that fixed my idle, it idles like a champ now, cept for the fact that mine doesn't run at all nemore, another thing on the list of failures-now i need another new coil Quote Link to comment Share on other sites More sharing options...
ZR8ED Posted March 16, 2005 Share Posted March 16, 2005 For idle.. check initial timing, and don't forget the obvious (idle speed screw) might be too low to hold an idle. Ya never know. oh and vacuum leaks...nasty.. Quote Link to comment Share on other sites More sharing options...
