mario_82_ZXT Posted March 17, 2005 Share Posted March 17, 2005 Is this right? IT IS COMPLETLY WRONG AND IT WILL BLOW Q5 AND D9 I forgot to draw the condensor which is hooked up to the coil + I have no spark, and in the original setup, the coil got 12v from the EFI relay, but it is not the case with this setup... Should I just put 12v to the coil +? I have gotten a spark twice, but thats about it. Thanks in advance, Mario Quote Link to comment Share on other sites More sharing options...
Tony D Posted March 17, 2005 Share Posted March 17, 2005 NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO! The wiring of the + side DOES NOT CONNECT TO THE FIDLE! The + ONLY connects to the B terminal on the GMHEI setup. You wre SHORTING THE MODULE!!! You will BLOW something in the FIDLE driver circuit trying to hammer the MS with the current draw of a coil! The + Terminal will also have a 12V supplied to it, from the ign switch... Why didn't you wire it like the Moby Stickie?!?!?!?!?!? Quote Link to comment Share on other sites More sharing options...
