280Bob Posted April 6, 2005 Share Posted April 6, 2005 I am trying to decide on what wheels to get and had pretty much settled on the Konig Rewinds in 15x7, but now that American Racing has brought out the Silverstone and offers it in 15x8 I might go with those. (Does anyone know if the bolt pattern is right?) My question is...if I run a 15x8 inch wheel with 5" backspacing will it clear my suspension? I am running the MM coilovers with 10" springs. I have searched and found that Tim240Z is running 16x8 with 5" backspacing but will this backspacing still work for a 15" wheel? Also, I would really like to have a wheel with a good sized lip...is it possible to run smaller backspacing than 5" to achieve this look? I am away at school and cannot take measurements for about another week...but would really like to get some opinions on what size to order. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted April 6, 2005 Share Posted April 6, 2005 If you run an 8" wheel with less than 5" of BS, you will likely need to roll your fenders, and depending on the BS you want, you may need to flare it. Tim Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted April 7, 2005 Share Posted April 7, 2005 The American Racing wheels are made to order. They will make them in any size and back space you want. That includes lug patterns more than likely. Quote Link to comment Share on other sites More sharing options...
Dat260 Posted April 7, 2005 Share Posted April 7, 2005 The American Racing wheels are made to order. They will make them in any size and back space you want. That includes lug patterns more than likely. Are you sure about that? There is a set I'am interested in. Ari Quote Link to comment Share on other sites More sharing options...
CruxGNZ Posted April 7, 2005 Share Posted April 7, 2005 The American Racing wheels are made to order. They will make them in any size and back space you want. That includes lug patterns more than likely. In a 4 lug, they will not go any bigger than 8 inches wide. I know this for a fact. !M! Quote Link to comment Share on other sites More sharing options...
Dat260 Posted April 7, 2005 Share Posted April 7, 2005 Hi Mat, Thanks for the info. Ari Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted April 7, 2005 Share Posted April 7, 2005 I was speaking baout the Silverstone's. I do believe Matt is right on the lug though. Sorry, I don't ever consider that since my car is converted to 5 lug and it is just so easy to do it these days. I would just figure out which wheel you just gotta have and plan accordingly. Quote Link to comment Share on other sites More sharing options...
280Bob Posted April 8, 2005 Author Share Posted April 8, 2005 Thanks for the responses guys that helps me feel better about placing the order. Quote Link to comment Share on other sites More sharing options...
Guest WHITEBOY Posted April 11, 2005 Share Posted April 11, 2005 Is a 4 lug Mustang wheel the same bolt patern? With a 15 x 7, what backspacing is required? I want the Tire centered between the coil and the wheel well lip. Quote Link to comment Share on other sites More sharing options...
Dan Juday Posted April 11, 2005 Share Posted April 11, 2005 I have 15x8" wheels with coilovers on the front of my car. I run 4 1/2" backspacing. I do have the SubtleZ front fenders though which give me about 1 1/2" more space. If you try and run 5" of backspacing with 15" rims you'll likely be rubbing your springs. Quote Link to comment Share on other sites More sharing options...
sparkynacho Posted April 12, 2005 Share Posted April 12, 2005 I checked with my local American Racing wheel dealer and they said the silverstone's are available in a 15x10 for $230ea. in a four lug pattern for a Z. Quote Link to comment Share on other sites More sharing options...
CruxGNZ Posted April 12, 2005 Share Posted April 12, 2005 I think I should rephrase my post above. It should read, anything bigger than 15" diameter wheels, they will not go any wider than 8 inches. They used to, but not anymore. !M! Quote Link to comment Share on other sites More sharing options...
280Bob Posted April 27, 2005 Author Share Posted April 27, 2005 Are you sure that a 15x8 wheel with 5inch back spacing will hit the springs? Will it hit only in the front, or the back as well? I am really worried now, I just placed the order yesterday. If anyone on here knows for sure that a 15x8 wheel will or will not clear front and back with coilovers please post. Quote Link to comment Share on other sites More sharing options...
Dan Juday Posted April 27, 2005 Share Posted April 27, 2005 I'll take some measurements (and maybe a pic) later and post here. If you have already ordered with 5" b.s. you can still use slip on spacers without problems. It's the other direction you can't fix, too little b.s. Before ordering mine I triple checked all my wheel, fender, coilover measurements and I came up with 4 1/2". Just to give myself a little room for error I ordered 4 5/8" b.s. Now I use 1/8" spacers. Quote Link to comment Share on other sites More sharing options...
280Bob Posted April 27, 2005 Author Share Posted April 27, 2005 Do you think that changing the backspacing to 4.75" would be better than using a spacer? From what others on this site have said I don't think anything less than 5'' will work...what do you think? Quote Link to comment Share on other sites More sharing options...
johnc Posted April 27, 2005 Share Posted April 27, 2005 When my 240Z had stock fenders and coil overs I measured and had Monocoque make custom 15 x 8 wheels for the car. The rims had 4.5" backspacing and I could get the tip of my little finger between the tire/rim and the lower spring perch without any spacers. I also had to roll the rear fender lips when running 225/50-15 tires. Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted April 27, 2005 Share Posted April 27, 2005 Bob, did you order the Silverstones? Quote Link to comment Share on other sites More sharing options...
280Bob Posted April 27, 2005 Author Share Posted April 27, 2005 Yeah I already ordered the Silverstones 15x8 with 5 inch backspacing. That's why I was worried about what Dan said. I was trying to avoid using spacers but I guess I ordered the wrong bs and will need them now. Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted April 27, 2005 Share Posted April 27, 2005 OK, Let us know how you like the Silverstones. I have wheels for my car but I would have gotten those had them been available last year. Do they do anything bigger than 15"? I've got 13" front brakes so a 15" would probably not fit. A 16" would be pushing it. Quote Link to comment Share on other sites More sharing options...
Guest Battle Pope Posted April 27, 2005 Share Posted April 27, 2005 Those are awesome! And the price isn't bad for that width... I might need those. Quote Link to comment Share on other sites More sharing options...
