Another question on the turbo install
EZ-E
I read when installing the turbo, well in my case the one Im installing you do need a spacer, (T3/TO4E), but I was reading to line it up properly that you would have to loosen the bolts and turn the housing to match the stock set up.
I know this will sound stupid but on which side is it better to do this? At the compressor side or the turbine side. Does it make a difference ?
Thanks.
That proceedure is so simple that you'd be better off just to loosen both sides, comp & exh, and clock it to where everything lines up and fits as you like it to, then tighten er up.... :D
The only reason I ever had to use a spacer was because of me steping up to a much larger turbine housing, which caused it to contact the manifold without the spacer to move it out, and away from the manifold.
It that the reason for you using the spacer?
