B/W 280zxt housing with ford T5 internals?
jtmny1999
Definitely doable:
http://forums.hybridz.org/showthread.php?t=98599
I believe you could do this with any number of different (stronger) T5 centers if you can work the custom input shaft and output end issues. I "think" that the Nissan bell and tail housings will bolt to most T5 centers.
I needed to have a custom pilot bushing made to adapt my GM input shaft to the L6 crank, also a custom driveshaft to hook up the Ford output yoke.
A Clutch disc with a GM hub + datsun friction ring was easy to get made.
Just goes to show that you can make anything fit anywhere if you're determined enough.
