datsun327 Posted April 8, 2005 Share Posted April 8, 2005 the main shaft is kind of hard to turn. even after i put gear oil in it still the same. the person that i bought it from said that it had been sitting for a few months but worked fine before he took it out. i have another r200 and the main shaft on it turns easy. any tips Quote Link to comment Share on other sites More sharing options...
Clifton Posted April 8, 2005 Share Posted April 8, 2005 8" Toyotas are 9-12 in/lbs. of preload. Nissan should be close to that. That is with out the carrier and ring gear in. You should be able to feel if it's tight by turning a little one way and then the other between the backlash before it contacts the ring gear. There won't be much movemant there will be a slight amount. Quote Link to comment Share on other sites More sharing options...
