Guest jjohart Posted April 12, 2005 Share Posted April 12, 2005 Can anyone refer me to a source for unused 280ZXT fuel injectors? I bought a set from Z Barn, used, last year, and they apparently are making my car run lean/misfire. The mechanic says they're showing too high resistance. Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted April 13, 2005 Share Posted April 13, 2005 have you tried adjusting the AFM?? anyway.. a good source for injectors is eBay!! i find them ALL the time Quote Link to comment Share on other sites More sharing options...
lifegrddude Posted April 13, 2005 Share Posted April 13, 2005 There was a place in Florida that advertises on zcar every so often with their pricing on fuel injectors. Something like 20 bucks a piece. That's very cheap since places like Autozone, Kragen, NAPA, etc charge ~40-50 a fuel injector. Quote Link to comment Share on other sites More sharing options...
randy 77zt Posted April 13, 2005 Share Posted April 13, 2005 do not install used injectors with out having them flow tested.i have some lucas injectors that i used for a few years on my zxt engine but i took them out.bought them new and always ran good.when i swapped in zxt motor i knew i didnt want to waste time trouble shooting nasty plugged injectors.engine is getting megasquirt with 42lb lucas injectors now.could you possably have non turbo injectors? Quote Link to comment Share on other sites More sharing options...
z-ya Posted April 13, 2005 Share Posted April 13, 2005 Send them out for cleaning and testing. I find it hard to believe that the impedance (resistance) is out of spec. The impedance should be in the 2.4 Ohm region. I've seen ones 2.2 Ohms, and ones 2.6 Ohms. They all worked fine after a good cleaning. It sounds like the injector just need a good cleaning and tesing. Pete Quote Link to comment Share on other sites More sharing options...
