chrismoose17 Posted April 15, 2005 Share Posted April 15, 2005 i have a weird problem. i have a 81 280zx turbo and when i start it, it runs alittle ruff and when i put it in drive it dies. any ideas? Quote Link to comment Share on other sites More sharing options...
Guest SpyderZ Posted April 15, 2005 Share Posted April 15, 2005 Chris, Please provide more info. When the car does this: did the car completely warm up? Do you still have all the stock sensors on the intake? This problem could be an EGR valve problem. It could be your VCM module sending the wrong signal to the EGR and caused the car to run rough. Quote Link to comment Share on other sites More sharing options...
GrayZee Posted April 15, 2005 Share Posted April 15, 2005 Also could be the AAC valve, lots of people disconect it without any issues. Quote Link to comment Share on other sites More sharing options...
Guest SpyderZ Posted April 15, 2005 Share Posted April 15, 2005 yeah I had removed everything on the intake except for the Vacuum control valve that screw into the 4th runner of the intake. My car runs perfectly fine. The only problem is it idles a bit low when cold. Quote Link to comment Share on other sites More sharing options...
Guest bastaad525 Posted April 15, 2005 Share Posted April 15, 2005 if you've removed everything then basically your car doesn't have a 'choke' anymore, in other words it doesn't have a way to run the higher idle it needs to run at when it's cold. I have a turbo motor but running an earlier 280z intake manifold that doesn't have ANYTHING on it, no cold start valve, no AAC, EGR, nothing. It too will idle abotu 200rpm low when it is cold, and when I first start it I need to push down the throttle slightly or it will just start and die. After it runs for about 5-10 seconds I can let off the throttle and it will idle. Quote Link to comment Share on other sites More sharing options...
GrayZee Posted April 15, 2005 Share Posted April 15, 2005 Thats why I still have my air regulator switch, it's kinda nice having fast idle if you are gonna drive it all the time. Quote Link to comment Share on other sites More sharing options...
