Intermittant Starting SBC 280ZX
danc
Guys:
Had another thread on this, but to simplify, my SBC ZX had an intermittant starting problem and everything else works perfectly. When it starts via ignition key, it fires right up without problem. Battery, starter, cables, grounds, ignition relay, and useable links are all O.K. When it doesn't start via ignition key, it starts no problem with a remote starter button jumped across the "S." terminal and the other jumper on the batt cable of the starter. I'm about ready to replace the Ignition Control Unit, or ignition switch, but thought I would ask one last time if there are any wiring wizards out there who could identify a potential iimtermittant problem to a component. I know the ignition switch is a "candidate" for an intermittant problem, but was wondering if there are any others that would cause this problem????
Thanx
Dan
