mas8230 Posted April 21, 2005 Share Posted April 21, 2005 I have the Summit 16 gallon fuel cell. It will not stop leaking around the white outlet washers. I tried tightening the fittings. It stopped for about 4 days, now it is seaping again. It is a brand new cell. I finally get the vent problem corrected, now this !!! Anybody have this problem ?? Any permanent fixes ?? Suggestions ??? Thanks. Quote Link to comment Share on other sites More sharing options...
mark Posted April 22, 2005 Share Posted April 22, 2005 Take it apart, clean it, replace the washers or put it back together with you favorite gasoline safe gasket goo on the washers Quote Link to comment Share on other sites More sharing options...
blueovalz Posted April 22, 2005 Share Posted April 22, 2005 I had the same problem with mine. I eventually put a softer (fuel safe) thin rubber-like washer between the white nylon ones and the cell material. This stopped it. Quote Link to comment Share on other sites More sharing options...
mas8230 Posted April 22, 2005 Author Share Posted April 22, 2005 Where did you get the fuel safe rubber washers? Any particular size? Thanks. Quote Link to comment Share on other sites More sharing options...
blueovalz Posted April 22, 2005 Share Posted April 22, 2005 I can't remember where I got it, but it (I think I cut it out of a small piece of sheet) made it the same size as the white nylon type of washer used by the fuel cell (about 1 1/2" in diameter). Quote Link to comment Share on other sites More sharing options...
