Which Injectors Will Fit 1981 ZXT?
Art Nadel
Gents,
My first posting on this site. I see some of my friends from
" westcoastZracers" are regulars.
All I need is a tad more flow than the stock injectors, and want some that will bolt in without modifications.
Have varioulsy been told that the stock units are 259 cc/min or 270 cc/min.
Also have been told the 84 300 ZXT are 370 cc/min.
Who can tell me with certainty if there are 370 cc/min injectors that will just plug and play. If not what will?
As you should know, my car has the dropping resistors. Have measured the injector coils and find 2.7 ohms.
Many thanks,
Art
Any low impedance injector (2.4 Ohm) that a hose can be attached to, and that has a Bosch style body will work The problem is that if you just drop in bigger injectors, it will run pig rich except when you need the extra flow rate at high boost levels. The stock injectors flow enough fuel for 11-12psi of boost.
Pete
