i think i know the problem!!
midnightzxt
ok, here's the deal, when i turn the ignition on, but not cranking, the pump goes through its priming stage. THEN, the fidle/spark green light lights up and stays on, which is taking the voltage away from the fidle wire. NOTE: this is the "extra" code. if you let the car sit for 10 seconds, is the only green light on the fidle/spark light? this is without the middle led on, meaning no dizzy signal.
click on the megasquirt install guide and then click the link to the megasquirt homepage and read :D
but to answer your question: FIDLE is the "fast idle" that is part of the megasquirt programming for cold starts. In our MSnS-E code, this FIDLE connection is used as a spark output for spark advance control.
