DaleMX Posted May 1, 2005 Share Posted May 1, 2005 What is the consciences here about the plastic splash guards under the fenders. Keep them or trash them. They are always in the way when working under the fenders and the clips just dont seem to work right. I was thinking about removing them and just trying to protect the headlight connector some other way. Quote Link to comment Share on other sites More sharing options...
Dan Juday Posted May 1, 2005 Share Posted May 1, 2005 They are a 280 only aboration. One of many contributors to Nissans weight gain plans for the S30. 240 & 260 owners get along fine without them. I'm sure you could too. Quote Link to comment Share on other sites More sharing options...
hanomon Posted May 1, 2005 Share Posted May 1, 2005 Kinda' depends on how much water you drive through. I see you're in Ga prolly way more rain than here in SoCal. As long as that weather seal between the body-pannel and quarter is good, you won't need to worry about splashing up into the door hinge area. I have used this space for much of the wiring as I ran all (except engine) wires through the frame and needed some where to transition the loom from inside to out. But then again I don't plan on getting soaked unless buy a soapy sponge in a bucket once in a while. Quote Link to comment Share on other sites More sharing options...
