Single Groove Harmonic Balncer, Where?
Guest iskone
Guest iskone
I don't know if you need it or not to be honest. I thought it was necessary. No impact is a bummer. Best you can do then would be to put the car in 4th and have someone stand on the brakes while you tighten the bolt.
I tried that when i took it off and it wasn't working. To take it off I made a stop out of a 2x4 bolted it to the block and when it hit the pistons I was able to get it loose.
I have another plan i think might work but I'm worried about my starter. In this plan I would get my socket wrench wedged against the ground and then turn the key. I would'n try and start it just barely engage the starter. I have a spare starter I might use for this.
As far as the new bolt is concerned from what I read it is a heat treated bolt with rolled threads. IMO it would be nice to have but I'm not paying $40 for a bolt I don't think is nessecery.
Isk
