Over-run Fuel Cut
mario_82_ZXT
Guest Loose_Screws
Mario, I never realized what this was! I was thinking 'over-run fuel cut' was when the engine was running away or something (held over thoughts from Detroit Diesels).
I will have to experiment with this and see. Fuel vapors fill the cabin on decel pretty badly and this would help eliminate that.
Give me a couple of days to test and I'll respond.
mario, that is an anti-backfire and fuel economy measure. You have settings basically approximating the last scenario, which is the only one you really needed to worry about.
The other two are anti-HC spiking control algorithms to lower emissions. If you aren't really coasting much or heavily decelerating constantly it will make little difference.
