Forged pistons from Z31 turbos
rayaapp2
Who here is running Z31 forged pistons in their L? I can't find any specs other than bore to tell me if they will work. Is there a problem with deck height?
Custom Rods maybe?
I've been searching for manufactures of forged pistons for my engine. Everything seems a little expensive. If Z31 pistons are as easy as using another rod setup and boring the block 1mm then finding aftermarket forged pistons for a Z31 might be easier than searching for "Datsun" L-series pistons... a.k.a. un-obtainium for under 400bux.
I'd much rather spend money on a turbo upgrade or somthing.
I've seen custom pistons for my 454 through Wiseco for less than that.
My first 3 liter stroker used Z31 pistons, 240z rods and a diesel crank. The Z31 pistons have a pin heigth that is 6mm shorter than a L series piston.Z31 turbo pistons would work fine for a 3 liter turbo build.Z32dett pistons will also work but the rods have to be modified to fit the larger 22mm pin that are also full floating rather than press fit like the L series.
