pjo046 Posted May 15, 2005 Share Posted May 15, 2005 Here are some pictures of the block after I took out the crankshaft. http://album.hybridz.org/showphoto.php?photo=2596&size=big&cat=530 Does it look like a little honing is all that is needed before installing new forged pistons? How can I get the headgasket residues of the block myself, without destroying the flatness of the block? getZ said that I will need to have the small end of the rods enlarged by a machine shopmachine because the forged pistons use floating wrist pins instead of press fit. So there is no way I can install forged pistons myself? I have to let a machine shop take care of it? Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted May 16, 2005 Share Posted May 16, 2005 Bump. Quote Link to comment Share on other sites More sharing options...
pjo046 Posted May 16, 2005 Author Share Posted May 16, 2005 huh? Quote Link to comment Share on other sites More sharing options...
wheelman Posted May 16, 2005 Share Posted May 16, 2005 Here are some pictures of the block after I took out the crankshaft. http://album.hybridz.org/showphoto.php?photo=2596&size=big&cat=530 Does it look like a little honing is all that is needed before installing new forged pistons? How can I get the headgasket residues of the block myself' date=' without destroying the flatness of the block? getZ said that I will need to have the small end of the rods enlarged by a machine shopmachine because the forged pistons use floating wrist pins instead of press fit. So there is no way I can install forged pistons myself? I have to let a machine shop take care of it?[/quote'] I don't know enough about the forged pistons to comment on those but just looking at the block will not tell you if a hone will be all it needs. You need to measure the bores to determine how much they've worn and then either have it bored out or honed. If I were you I'd have it bored and honed by a good machine shop because you're spending money on new pistons anyway. You'll want to do the same for the crank and rods. Measure them both to determine how much they're worn so that you know the correct size of bearing to use when you reassemble the engine. Take the crank and rods to the same machine shop where you get the block work done and have them check, measure and resize the rods and polish the crank. They'll be able to tell you the bearing size to use and probably sell them to you. Think about having the head looked at as well while you have everything torn apart. You might as well do it right if you're going to do this at all, otherwise you'll be tearing it back apart later to redo the things you don't do now. Wheelman Quote Link to comment Share on other sites More sharing options...
getZ Posted May 17, 2005 Share Posted May 17, 2005 If you didn't get the pistons yet and they are a custom order, you can order them with a press fit pin. Not sure if it's the same price or not. The cost of reworking the rods is not that much. I have a machine shop here in the US that will do the work for about a couple hundred bucks for the set. That's not just for the small end of the rod. It's for magnufluxing, hot tanking, resizing both small end and big end for out of roundness. Not sure what shipping is from your part of the world. I do have a colleages in the Netherlands who knows of a few reputable shops. Not sure if that any cheaper either. Quote Link to comment Share on other sites More sharing options...
EvilRufusKay Posted May 17, 2005 Share Posted May 17, 2005 Bump. Cygnusx1 is just bumping your post so that it will stay new when people hit the "new posts" button. Quote Link to comment Share on other sites More sharing options...
