They'll work fine... since they're only being used as a shop wheel and they'll never be used on the street. If you run into any difficulties (due to the center mounting diameter being smaller) you can make some simple plywood spacers to push the wheels out a bit. Just remember to throw those CCW's on before heading out, eh? :wink:
ok ok so maybe they don't fit perfectly. Both of you guys are right, the hub center is about 1/4" in diameter too small. Guess I should look a little closer next time...:redface:
I was considering using a spacer or simply routing the hub center out with my grinder. The spacers will be less work I think however.
Thanks for the help guys, I will let you know how it turns out.
Rufus
