stagefumer11 Posted June 3, 2005 Share Posted June 3, 2005 can someone confum, L28e injector size is 185cc's ? Quote Link to comment Share on other sites More sharing options...
slownrusty Posted June 3, 2005 Share Posted June 3, 2005 I believe you are correct sir....L28ET are 210s Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted June 3, 2005 Share Posted June 3, 2005 I thought Turbo injectors were 260cc's. Mario Quote Link to comment Share on other sites More sharing options...
Guest duende1933 Posted June 3, 2005 Share Posted June 3, 2005 Mario is correct, the injector size for the l28 turbo is 260 cc Quote Link to comment Share on other sites More sharing options...
stagefumer11 Posted June 4, 2005 Author Share Posted June 4, 2005 Thanks for the Replys Greatly Apericated. Question again, Im currently going Through a large amount of injectors, It seems the base of the injector stalk always seem to crack. has this been knowen to be common ? im getting sick Of trying to sorse injectors for the old girl. Im presuming its because of age and maybe fuel pressure but thats the only thing that seems to blow them. What can i use that a similar rating, or even 260cc's ect, I remind you this is in New zealand where anything l28 is impossible to get. Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted June 4, 2005 Share Posted June 4, 2005 I think you might be over tightening them. Are you cracking where the they sit on the manifold or where they are held on in place by the insulators? Mario Quote Link to comment Share on other sites More sharing options...
stagefumer11 Posted June 4, 2005 Author Share Posted June 4, 2005 ah., well im not doing them up tight, They actually break at the base of the barb. when installed. It is at ramdom. my last one was 6 months ago. YOu will find two indentations on the side of the injector at the base of the barb. thats where they start leaking from. My last one Which is still in the car is at the bast of the barb not at the indentations. Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted June 5, 2005 Share Posted June 5, 2005 What type of clamps are you using? Can you post pics of where its leaking? If its at the body I have (I think) 4 spare NA injectors. Mario Quote Link to comment Share on other sites More sharing options...
stagefumer11 Posted June 5, 2005 Author Share Posted June 5, 2005 ah sorry no pics atm soonish. need to sort it. Im using proper Fuelline hose clamps. on the whole lot. The first time it happend i had never touched the fuel side of the system. it was factory. Im just presuming its old age. I hope Quote Link to comment Share on other sites More sharing options...
stagefumer11 Posted June 9, 2005 Author Share Posted June 9, 2005 ok, A NOTHER ONE IS CRACKED worse than before, how the hell is this happening ? what can cause them to leak out the body themselfs? Quote Link to comment Share on other sites More sharing options...
