seth Posted June 7, 2005 Share Posted June 7, 2005 From my searches it seems that it is possible that a mustang T5 would bolt up to the Nissan Bell housing. Is this the case? I know that you would need to do a custom clutch and driveshaft, but what i am wondering is if it would bolt up and if the input shaft is the correct length. Quote Link to comment Share on other sites More sharing options...
Cody 82 ZXT Posted June 8, 2005 Share Posted June 8, 2005 Do some more searching the answer is there. Quote Link to comment Share on other sites More sharing options...
Sparks280zt Posted June 8, 2005 Share Posted June 8, 2005 i have heard that it would with some modification to the input shaft, you might wanna ask ZCarsmakemyheadhurt, i think he knows somethin about it Quote Link to comment Share on other sites More sharing options...
seth Posted June 8, 2005 Author Share Posted June 8, 2005 I just found that it will bolt up but the front bearing carrier is larger and would have to be machined larger... now is the input shaft the same length? Here is the reason, I am thinking of the T56. The one used as a upgrade for mustangs is usually the .63 6th. Now as an upgrade for the Mustang you can pickup a T56 with a slightly longer input shaft and an adapter plate the bolts the trans to the bell housing. Now if this is the case then the upgrade seems more reasonable, at least when you compare it to the G-Force upgrade at 2500. Quote Link to comment Share on other sites More sharing options...
