konig rewinds with toyota brakes
Easy way to tell, do the calipers say "S12" or "S12W" on them? The latter are for vented rotors and are off the 4Runner.
Edit: I just realized you could be correct, maybe they had an 84 4Runner in the US but not in Canada? Stranger things have happened.
Here is the setup that I have. Any idea what the hubs are from? As I just got my rewinds and test fit them, I can say they definitely do not fit without spacers on my setup. They need at minimum, just under 1/4" of spacer.
those are 280z, you either need to put spacers and get longer studs or get the 240z scalloped hubs
I've got the scalloped hubs also, but since the spacer I have is for this setup, I'm going to run wheel spacers and stick the wheels out a little farther, rather than buy a new set of brake spacers for behind the hub.
then yea just get the wheel spacers and a little longer studs.
  • 2 months later...
