Guest error* Posted June 17, 2005 Share Posted June 17, 2005 I am wanting to run Megasquirt on a SR20DET. Seeing how this is a Nissan forum. I was hoping that someone had already gone through this. Anyways, I am actually wondering on the ignition. Seeing how they are all COP (Coil on plug) I know that the trigger wheel in the Cam Sensor can be decoded, using a pull up resistor (because it is optical). But I am wondering about the stock ignitor, does anyone know if megasquirt can drive it? Is it any similar to a HEI unit? Jacob Quote Link to comment Share on other sites More sharing options...
Guest 81na ZX Posted June 18, 2005 Share Posted June 18, 2005 Check on msefi.com . Someone should know the answer, or atleast get you started in the right direction. Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted June 18, 2005 Share Posted June 18, 2005 I think you end up switching to EDIS or a similar distributorless ignition. You can also keep the stock ecu and have that control timing. Mario Quote Link to comment Share on other sites More sharing options...
Tony D Posted June 18, 2005 Share Posted June 18, 2005 Actually, with the slotted cam timing sensor, I don't see what the problem would be going to MS-n-EDIS. Failing that, converting any of a number of Distributors to be driven off the cam angle sensor would be straightforward and then allow convetnional single coil usage with conventional plug wires. Didn't some earlier Non-US versions of the SR come with a distributor? That would also be an option. Quote Link to comment Share on other sites More sharing options...
Jsquared Posted June 20, 2005 Share Posted June 20, 2005 All RWD SRs are non-US The non-turbo SR20s all used distributors with wires, only the turbo models were coil-on-plug. Quote Link to comment Share on other sites More sharing options...
