Source for aftermarket rods/pistons, etc. (RB25)
Guest Benito
Guest Benito
Dude...
Maybe I'm not as smart as you, but all I saw were a bunch of sites with STOCK replacement parts. Is it that nobody makes aftermarket pistons for an RB25? I find that very hard to believe!
I searched:
rb pistons
pistons
aftermarket pistons
rb25 pistons
YOU come up with a thread that says "here is a link to some forged pistons for an rb25" and I will give you 20 bucks from paypal right now. It's always good to protect your board from morons. That's great. I'm not a moron.
Dude...
Maybe I'm not as smart as you' date=' but all I saw were a bunch of sites with STOCK replacement parts. Is it that nobody makes aftermarket pistons for an RB25? I find that very hard to believe!
I searched:
rb pistons
pistons
aftermarket pistons
rb25 pistons
YOU come up with a thread that says "here is a link to some forged pistons for an rb25" and I will give you 20 bucks from paypal right now. It's always good to protect your board from morons. That's great. I'm not a moron.[/quote']
No need to get bent out of shape. There was no offense intended in my initial reply and nobody implied you were a moron. Now...
In 5 minutes I went throught the links in the post I referred you to and I found 4 links that either offered forged pistons or had links to companies that had them.
http://store.yahoo.com/phase2motorsports/cpfopikitrb.html
http://www.rb25det.org/ (2 links under the 'LINKS' section)
http://uniqueautosports.com/ (Parts Catalogue > Engine Parts)
http://www.japaneseperformanceparts.com/wiseco-cylinder-forged-piston-kits-p-3268.html
ALL of these could be accessed from the links provided in the RB20/25/26 Links thread. What more do you want?
Guest Benito
I owe you 20 bucks.
What's your paypal addess?
That's all I wanted. I'm not bent out of shape, don't worry (sure you aren't) :twak: So maybe I am a moron or maybe I'm just lazy.
Thanks!!
Here is a link to a source for custom pistons. Give them your specs and they will make em.
http://www.ariaspistons.com/custom.htm#
Just about any piston manufacturer will make custom pistons. Of the last 10 sets of Arias pistons I bought, 8 sets came with the wrong rings. In every case, the rings were replaced at no expense to me, but when a customer is waiting for the engine......Good pistons, but a couple of times, the supplied rings could have been installed by someone not thouroghly checking, and would have had disasterous results. I use JE and Wiseco now.
Matt' date='
Thanks for the info about Arias. I have been debating using off the shelf Wiseco's or custom made for my RB30DETT.[/quote']
I also have had a bad experiance with Arias. I would recomend CP pistons. They will make anything you need. Pauter rods are also what I would recomend. They are a bit pricey but they are some of the best out there.
