2003z Posted June 21, 2005 Share Posted June 21, 2005 I've got my rear struts totally disassembled to do a rear 280zx brake conversion, and have all the necessary parts, but am trying to figure out how to remove the drum brake backing plate and dust shield from the strut tube assemblies. Do I just unbolt the 4 center bolts, unbolt the 2 10mm bolts holding the brake assembly at the bottom and cut off the 2 welded rivets at the top to remove them? or is there more? thanks! (every brake conversion thread seems to assume this portion is obvious.) Quote Link to comment Share on other sites More sharing options...
auxilary Posted June 21, 2005 Share Posted June 21, 2005 you will need to do one of two things: 1. cut through the backing plate with a sawzall or plasma cutter and cut it in half 2. remove stub axle nut in back (240ft lbs torque), separate stub axle and joint, and remove backing plate since it's wedged between the two Here's a link to 240sx conversion install, which is the same principle: http://zhome.com/ZCMnL/tech/Calipers/zbrakeupgrade.htm Quote Link to comment Share on other sites More sharing options...
2003z Posted June 21, 2005 Author Share Posted June 21, 2005 you will need to do one of two things: 1. cut through the backing plate with a sawzall or plasma cutter and cut it in half 2. remove stub axle nut in back (240ft lbs torque)' date=' separate stub axle and joint, and remove backing plate since it's wedged between the two Here's a link to 240sx conversion install, which is the same principle: http://zhome.com/ZCMnL/tech/Calipers/zbrakeupgrade.htm Thanks! I've got the stub axle out already (the shop really f'ed up the threads on it though. So much for paying a professional. Guess I will get to work! Quote Link to comment Share on other sites More sharing options...
2003z Posted June 21, 2005 Author Share Posted June 21, 2005 I chose #2. They were fairly rusty, so it appeared as if the backing plate was part of the strut tube base. I used an air chisel and it busted right loose. Quote Link to comment Share on other sites More sharing options...
AK-Z Posted June 22, 2005 Share Posted June 22, 2005 Where did you ge the caliper mount? I want to do a disc conversion as well ( I always want to do everything to my car). Is it just removing the rear drums, shields and back plate and bolt the adapter, caliper and discs? N/M about where you go the mounts. Quote Link to comment Share on other sites More sharing options...
2003z Posted June 22, 2005 Author Share Posted June 22, 2005 Where did you ge the caliper mount? I want to do a disc conversion as well ( I always want to do everything to my car). Is it just removing the rear drums' date=' shields and back plate and bolt the adapter, caliper and discs? N/M about where you go the mounts.[/quote']Got them used. yes basically thats all there is to it. Quote Link to comment Share on other sites More sharing options...
